Fuel petcock replacement
Hi all, tried to some searches online and on forum and came up empty handed, is there no other Honda model that shares the same petcock as the 1980 CBX? Called Honda today and they told me no parts or whole thing!! thanks in advance, Fred.
Cheers, Fred
1980 CBX
1973 CB750 K3 (waiting...)
1970 CB750 K0
2001 Electraglide
2006 KTM SF-X 250
1980 CBX
1970 CB750 K0
2001 Electraglide
2006 KTM SF-X 250
- desertrefugee
Re: Fuel petcock replacement
Rebuild kits are readily available. My 10 year sleeper leaked like a sieve. I drilled out the rivets and put a kit into it, but put it on the shelf and replaced it with a Pingel.
“Pass more gas” as they say...
put a Pingle on mine too. works great.. no more leaks.
PAST:
75 Kaw 900 Z1 drag and street bike
82 Kaw GPZ 1100
85 HD Low rider (1st Hawg)
83 Kaw GPZ 750 Turbo
93 Kaw ZX1100
96 HD Standard Bagger, 96" Stroker with Nitrous 125 hp
02 BMW K1200LTC
04 Triumph Rocket III 140 hp
05 Triumph Rocket III Classic
09 HD Standard now custom Street Glide
10 Triumph Bonneville Café Type
NOW:
2018 HD Road Glide Special
79 Honda GW 1000 naked museum bike.
81 Honda CBX had Zero Miles, in storage since new, serviced and am now riding, and loving it.
82 Kaw GPZ 1100
93 Kaw ZX1100
02 BMW K1200LTC
NOW:
Most older Hondas used the same rubber "biscuit" as the CBX. Just drill out the rivets and tap the holes for small screws. Way cheaper than a Pingel, and it will flow more gas than a stock bike can use.
'79, '80', '81 all had the same petcock
Have a look at a rebuild post from Randakks.
http://www.randakksblog.com/petcock-reb ... ro-update/
Well, almost. The '79 petcock had a 1/4 inch outlet and a longer standpipe for reserve, which took a '79-only screen. You can run without the screen but you need the o-ring. The '80-'81 petcock had a 5/16 outlet and a different reserve standpipe. That screen kit is still available for about $40. Most all NOS petcocks you find now are the 469 part number. It is really hard to get an old screen out of the tank without ruining it. But any of the above can be rebuilt to work find as mentioned previously.
