Carb bowl drain screw O rings
- GLHS60
Hello!!
I'm sure this has been asked many times but I am in need of the O rings that fit the carb drain screws.
Local Honda dealer says none available.
Anyone know of a source for these, I'm itching to go for another ride!!
Randy
Randy
SHERWOOD PARK
ALBERTA, CANADA
86 GLHS60
86 GLHS373
79 CBX SLIGHTLY MODIFIED
ALBERTA, CANADA
86 GLHS60
86 GLHS373
- spencer
Re: Carb bowl drain screw O rings
In the mean time, until you find o-rings, I think you can ride all you want. Just screw the screws in till the bowls do not drain. The screw seals the bowl drain, not the o-ring. The only purpose of the o-rings is to prevent leakage when you loosen the screws to drain the bowl.
SCH Rochester, MN
- GLHS60
Really??
Now that you mention it, it makes sense.
I'll report back tomorrow.
Randy
Randy
spencer wrote:In the mean time, until you find o-rings, I think you can ride all you want. Just screw the screws in till the bowls do not drain. The screw seals the bowl drain, not the o-ring. The only purpose of the o-rings is to prevent leakage when you loosen the screws to drain the bowl.
SHERWOOD PARK
ALBERTA, CANADA
86 GLHS60
86 GLHS373
ALBERTA, CANADA
86 GLHS60
86 GLHS373
Tims still has them listed in their catalog.
http://www.timscbx.com/Carburetor%20page%201.html
- GLHS60
Appreciate the replies!!
I had a nice ride, without o rings, LOL
Carbs are probably plugged, draining them a couple of times didn't help.
Needs some choke even when warm, normal after a long rest I suppose.
I drained them years ago but I guess "carb crustys" never sleep.
At the time I never dreamed I would let it sit so long.
Randy
Randy
SHERWOOD PARK
ALBERTA, CANADA
86 GLHS60
86 GLHS373
ALBERTA, CANADA
86 GLHS60
86 GLHS373
Before you remove the carbs for a proper cleaning have a look at this on-bike cleaning tutorial from Mike Nixon.
A long shot but MIGHT be worth a try.
http://www.motorcycleproject.com/text/c ... short.html
As Dave points out it will take most of us 2 or 3 attempts at getting them sorted.
- GLHS60
I appreciate the link!!
Mike Nixon seems to be "the man"
I saw a youtube where a guy drained his carbs, filled them with seafoam and let it set overnight.
I have no experience with seafoam, has anyone tried this or is it discouraged.
Randy
Randy
SHERWOOD PARK
ALBERTA, CANADA
86 GLHS60
86 GLHS373
ALBERTA, CANADA
86 GLHS60
86 GLHS373
I use 2 or 3 ounces of Seafoam 2 or 3 times a year in a full tank of gas.
Somebody here found an analysis saying that it was mostly alcohol so i wouldn't bother with the overnight soak.
MIGHT not be good for the o-rings either.
- CopperCollar
Member of the been there done that crowd in regards to the CBX carbs.
The 79 sat a little longer than I realized with ethanol fuel in it. Very hard to start and ran very crappy. Flushed the float bowls of baby crap green fuel then tried the seafoam method in a tank of fuel it helped but the bike was still not running right.
Lesson learned, drain float bowls and run ethanol free fuel when I can.
- FalldownPhil
Mike,
There have great reports of success using some Techron in the fuel tank. It is currently on sale at Costco @ about 30% off.
Maybe try a heavy dose through your carbs.I think I paid $20.00 for a case.
- Mike Nixon
Better late to the party than never, I guess.
I would add that Honda themselves decided later the o-rings were superfuous. Though using the same exact screw, with the o-ring grooves, all the 90s carbs have no o-ring.
