Page 2 of 4
Re: 4000rpm bog
Posted: Sat Jul 16, 2022 6:47 am
I guess the bottom line is, you can check the jets by removing #6, but as Bob said, you have no idea what the carbs are really like, what jetting, needles, really anything. They need a complete rebuild with stock parts.
A good indication that they need looked at is the fact that when you got the bike, the airbox was off. Why could that have been?
Re: 4000rpm bog
Posted: Sat Jul 16, 2022 9:23 am
by CBX-tras
Remove the alternator and access to the #1 float bowl is about the only one you can get to in sitsu, easily.
Remove the bonnet too, check to see if the slide has the stock needle or something else. The needle should be anodized aluminum with 05F stamped near the top. If not stock, this indicates that the carbs may have been altered internally.
But, what about the exhaust? Stock, aftermarket? That can cause performance issues too.
Re: 4000rpm bog
Posted: Sat Jul 16, 2022 5:07 pm
by bobcat
Yeah, any way you look at it the carbs will have to come off so you might as well
get it over with and know for sure what you have. Do a compression test while the
carbs are off.
Re: 4000rpm bog
Posted: Sat Jul 16, 2022 5:21 pm
by bobcat
You might as well check the valve clearances and tension the cam chains* too while you have easy access.
Do it all and ride with confidence !
*not the FSM procedure.
Re: 4000rpm bog
Posted: Wed Jul 20, 2022 4:12 pm
by Salman_z8
Thats what i had thought, i will proceed to removing carbs.
And establish a baseline, worst case scenario at least i will know whats in em for brass
Re: 4000rpm bog
Posted: Wed Jul 20, 2022 4:13 pm
by Salman_z8
It has a dg 6-1 on it right now, down the road will get a set of repro 6-2 pipes
Re: 4000rpm bog
Posted: Thu Jul 21, 2022 8:03 am
The DG will give you a mid-range stumble, perhaps not as bad as you are seeing though.
Re: 4000rpm bog
Posted: Thu Jul 21, 2022 8:40 am
by bobcat
I'll bet the PO attempted to jet for the DG and, since the air box was off,
might have been planning to run pods, got the primary and secondary main
jets switched and/or put a Dynojet stg.3 kit in them. Exploration will tell.
Re: 4000rpm bog
Posted: Thu Aug 18, 2022 6:58 pm
by Salman_z8
Havnt had a chance to take the bank off yet, will do once the weather gets a bit cooler.
But i am thinking the same thing as bobcat
Re: 4000rpm bog
Posted: Thu Sep 22, 2022 11:22 pm
by Salman_z8
Fired it up yesterday, started and idled perfect.
So naturally i blipped a throttle enough times to annoy anyone in close proximity.
Cooler day, so spent a good 4-5 mins.
Not the correct way i know, but i did check the plugs after, and indeed the plugs are sooty.
Now i was also seeing a little blue smoke, but i do think gor sure that something is off with the carbs.
Since smoke is more so evident now, that the airbox is on, so it might be that the mains are interchanged.
Who knows what else is in there for brass.
Baby sitting my daughter these days, so only get 3 hours per day during the week while she is in pre school.
On a different note, finished a few others and even sold a couple to make some room.
I have another cbx as well, a thread i started a long time ago, i think pretty soon i will start to make progress on both the x’s.
Re: 4000rpm bog
Posted: Thu Oct 13, 2022 12:48 am
by Salman_z8
Hi
Would anyone be able to post a photo of how the wring connectors sit inside the headlight bucket ?
I have finally got a chance to get started on this bike again.
Finally got the gsxr front end pieces off, and have a reproduction headlight bucket. I would like it to go as factory as i can, without being too ocd
Re: 4000rpm bog
by Salman_z8
Next up will be addressing the carbs
Re: 4000rpm bog
Posted: Thu Oct 13, 2022 1:05 am
This is not a perfect execution of this, but it’s B+. There’s a great clear diagram in the shop manual.
Re: 4000rpm bog
Posted: Thu Oct 13, 2022 8:50 pm
by Salman_z8
NobleHops wrote: ↑Thu Oct 13, 2022 1:05 am
Thank you so much.
That helped.
Also found the diagram as well.
Much appreciated
Re: 4000rpm bog
Posted: Wed Mar 22, 2023 9:36 pm
by Salman_z8
Update.
Carbs are off the bike.
Spoke to bob, thanks bon for your time and insight
