Loudest exhaust in the world - Baffle help appreciated!
You are seeing roughly half of our forum - what's here, how to register to see the remainder
Leesemike
Post by Leesemike »
Hi guys, thanks for allowing me to join. Got my first 1985 CBX 750F just like my late dad and love it! However, it is clear the exhausts are still as nature intended, and also clear that the baffles need some attention / re wrap. It is outrageously loud and I need to address it. On the attached pictures, can these rivets at the end of the can be drilled out and the baffle pulled away? Any advice is much appreciated! Mike.
shrap66
Re: Loudest exhaust in the world - Baffle help appreciated!
Post by shrap66 »
I’m sure if you are careful removing the rivets should be a piece of cake.
Start with a drill bit slightly smaller than the smaller rivet hole in the center. Drill it out slowly then increase the drill diameter if it’s not enough. Don’t push too much as to not hit anything but you should clear the baffle.
Luc
1979 KZ1000
1982 CBX1000
1983 GS1100SD Katana
2010 FLTRX
Return to “New Users - Start Here”
