CBX '79 With Kawasaki ZX-9R & Yamaha FZR1000 suspension
RC 166
Re: CBX '79 With Kawasaki ZX-9R & Yamaha FZR1000 suspension
Post by RC 166 »
Thanks Larry,
I found this nice radial master cylinder at a bike breaker. It came off a Suzuki GSX-R 1000 ’07 that has Tokico 4-pot calipers with 2x30mm + 2x34mm pistons just like in my Nissin 4-pots. This master cylinder has a 19mm pison.
"The 18 vs 20mm settings:
-The 18mm setting provides a little more feel, and a lighter pull on the lever is required. Consequently the 18mm has better modulation characteristics, i. e. more feel. Brembo says this is better for the track.
-The 20mm setting provides a quicker braking response; Brembo says this is better for the street."
This i supposed to work great with the Nissin 4-pots. I will install braided brake lines directly from the master cylinder to each caliper (no splitter used).
Own a one-man CNC shop, Building a CBX '79 with ZX-9R suspension and lots of nice custom CNC parts...
/ Peter
RC 166
Post by RC 166 »
I also bought this nice brand new front fender for a Yamaha FZS 600 ca '03.
Just have to be painted Candy Glory Red as the rest of the body parts.
/ Peter
Larry Zimmer wrote:
Mon Feb 05, 2024 12:32 pm
Superb!! Engineering at its best.
Agreed!
Peter, your attention to detail is amazing.
512tr
Post by 512tr »
Looking very good. :clap:
What clutch lever and switches do you plan to use?
Have you considered converting to hydraulic clutch when you are on it?
RC 166
Post by RC 166 »
Thanks 512tr, Steve!
512tr,
I have parts to convert to hydraulic clutch from Kawasaki, Suzuki, Honda and have also looked at mikeybikey's hydraulic actuator at the clutch arm which I think was the neatest solution before I ditched the whole Idea. If it is working well as it is, why change it and add a heavier lever, messing with hydraulic fluid etc.? I have never experienced any problems with the cable clutch, so will keep it.
I have switches from ZX-9R, Suzuki GSX-R1100, Honda CBR 1000 and I will try to fit the ZX-9R ones. I may have to use the CBX clutch lever, but will try to find a better looking one for cable. The OEM CBX stuff looks a bit dated IMO. Maybe also fit a stealthy choke lever separated from the clutch unit.
Okey, now I have mounted the tank and seat so I can try and evaluate the best possible position of the foot pegs. For this I am making some mock-up rearset plates with multiple peg positions to choose from. See more about the rearsets here: viewtopic.php?f=102&t=12693 What do you think about the stance?
/ Peter
I have some pictures of rearset setups that I have found interesting over the years but I have no knowledge of their operation, I can post a few, some are very minimal, others have heel guards and some are fully adjustable.
RC 166
Post by RC 166 »
Thanks Jeff!
I like the alu stuff, very nice!!
Can you please post these rearsets in the other thread as well. viewtopic.php?f=102&t=12693
I will just mention my rearset progress briefly here and do the all in rearset discussion over there....
/ Peter
512tr
Post by 512tr »
RC 166 wrote:
Tue Feb 06, 2024 2:07 pm
512tr,
In case you pick up the idea again😊, I can recommend this Frando clutch cylinder. I use Brembo pump and Ducati hand control unit with integrated choke lever.
RC 166
Post by RC 166 »
I will try to fit these switches from ZX-9R. The left switch also has a very thin choke lever.
I dont intend to use a hydraulic clutch lever, I will look for something like this.
/ Peter
jt
Post by jt »
I did a similar handlebar switch mod, except I used a Euro CBR throttle switch with H/L Off/ running light / headlight and front exit throttle cables for clearance to the tank when full lock to right and a Euro 94/95 CB1000 Big One for clutch side, I wanted the index finger Flash to pass switch, sometimes like a quick look ahead and find it quicker & easier to use than reaching for the thumb button. I had to use a modified 2006 CB500F choke cable to be able to clear tank at full lock, choke function is still smooth. Also used a 06 CB-919 clutch lever perch, I am running a low rise Rizoma bar.
Admire all the work you've put into your build !!!
JT In Texas
the mirror every mornin'.
RC 166
Post by RC 166 »
Thanks JT!
I test mounted my ZX-9R switches, throttle etc. It seems to clear the tank when at full lock (I have restricted my steering angle due to the step-down yoke). In future I might redesign the top yoke a little so i get back some steering angle. My bar is 800mm wide and with these controls I can cut 15mm on each side. Any bar end weights will be installed inside the bar, not protruding at all.
/ Peter
hondaman160mph
Post by hondaman160mph »
I admire your skills. Have you considered having longer fork
tubes made to avoid using the step down top yoke?
RC 166
Post by RC 166 »
Thanks hondaman!
I thought of that initially, but the ZX-9R top yoke does not have any bar mounts, so would probably have made a new flat top yoke anyway with mounts. And the top yoke must have the correct dimensions to accept the CBX stem, nut etc...
Anyway, happy with this solution for now.
/ Peter
Return to “Project Threads”
