Hi all,
Bought this 9 years ago, finally staring the project. Not one for the purists as I will be fitting Suzuki GSXR running gear and remodelling the bodywork, hope to have it done in time to ride it next summer.
Will be asking loads of questions as this is the first CBX I have done
81 Pro-link project
81 Pro-link project
Re: 81 Pro-link project
Be it resto-mod or stock, always good to have a build to follow.
Here to help if I can.
Got the cams out, all are in spec for run out, exhaust cam lobes are in spec, inlet cam service limit in shop book is 36.9mm a couple of mine are 36.45 and 36.55 are they scrap?
Cheers
Gladders
Cheers
Gladders
I see you got your answer on Facebook, but to reiterate, yes, they'll be fine.
Thanks Dave, always better to have it confirmed more than once
Cheers
Gladders
Cheers
Gladders
Got the head and barrels off this week, had to remove the studs as the barrel was stuck solid, bores and pistons look ok at first glance but will measure them up when I have completed the strip down.
