Dont how I got two threads.daves79x wrote:You need to combine the threads - this is getting confusing.
and I have idea no how to combine or eliminate, but I'll try.
I've done that too, "measure twice, cut once" but measuring twice doesn't help if you measure it the same way twice...Mouse wrote:I was sure you had checked the wires . But i can't count the no# of times i've found something wrong with the thing i checked and re-checked etc. etc.
Good Luck with it.
petcock is clear.daves79x wrote:So you need to find out what the fuel delivery problem is first. Did you check for sure the flow from the petcock and for the presence of a vacuum valve on the carbs? There has to be an obvious problem. Maybe floats installed upsidedown - don't laugh, I've seen it. But Mike is correct, I fear you have more than one problem.
I may try it again but instead of spraying into the air cleaner I'll remove some plugs and spray directly into the cylinders.EMS wrote:Any motor that I ever had, including the CBX six and a pressure washer Honda single, ran a couple of rpms when fed starting fluid. Even if the carbs were bone dry.
After you get fuel into all bowls, my guess is, it will still not fire.
We are talking about the 6 armed octopus underneath? I pulled those all off and they were open.daves79x wrote:How are the bowls vented? I've seen guys install solid rubber tubes on all vent connections, effectively preventing fuel from flowing, but some still should. Should be something obvious to see here.
Not sure that I would do that. The fluid washes off the oil on the cylinder walls. Besides, it is not the pure fluid that ignites, but an air-fluid vapor. Taking the air cleaner element out and spraying it liberally, yields best results.wyly wrote:I may try it again but instead of spraying into the air cleaner I'll remove some plugs and spray directly into the cylinders.
As far as I know the carbs were never split so those tubes should still be original. The carbs were opened up and given a sonic bath and he installed part of a keyster rebuild kit that I supplied. The tees on the vent lines were torn and had fallen off, he said the carbs would work without them. I pushed them back on regardless, I figured even torn they would help keep water out.daves79x wrote:No, those are the bowl drains. The bowl venting system connects the vent holes in each carb body through 2 common manifolds heading towards the center. Each side originally had a vent 'T' with a hose to atmosphere.
I know you paid someone some large $$$ to do all this for you and hoped you didn't have to deal with or even understand much of this - it should have just worked. But it doesn't. If you are willing to learn a bit about how everything goes together, we'll certainly help you figure it out.
Either something is holding fuel from flowing through the carb manifold via a blockage, or the needles are stuck tight in there seats, or are being held there due to incorrect assembly. Or the bowls aren't venting. How deep are you willing to dig to find it?
Mike is right, it should have at least fired on ether. If your static timing is correct - did you check that yet? - I'd probably not turn it over until I checked the cam timing. Bent valves will result if that's off by much, but that would have already occurred by the amount of cranking you've already done.
The spark plug wires just have to be paired correctly to the coils. Both fire at the same time. You just have to make sure it goes 1-6, 3-4, 2-5, left to right and you have the primary side wires connected correctly.
Okay. I thought I sprayed in a lot but maybe I didn't, I'll try it again.EMS wrote:Not sure that I would do that. The fluid washes off the oil on the cylinder walls. Besides, it is not the pure fluid that ignites, but an air-fluid vapor. Taking the air cleaner element out and spraying it liberally, yields best results.wyly wrote:I may try it again but instead of spraying into the air cleaner I'll remove some plugs and spray directly into the cylinders.
